Automate Dwg notes
Automate Dwg notes
I have downloaded Lenny's SolidWorks macro "CommonNotes". I need to add my own notes and also have them list from bottom to top. I tried editing the macro with no luck. I tried emailing him, with no luck. Has anyone tried editing it, or do you have your own macro that works like I need.
Thank you, ctopher
Thank you, ctopher
RE: Automate Dwg notes
Did you place your notes in the .INI file?
Where can I find that download, I would like to take a look at it.
Chris
Out dwgs have notes starting with note 1 at the bottom going up. The macro only allows me to go down. Can this be changed in the macro?
thank you
I have tested it and added some notes of my own and all works fine
The trouble is I need to have all my notes in both English and Chinese
The macro doesn’t support Chinese text it would be a good tool to use if could
Any suggestions
MachineSMMC
Lennys website can be found at http://webpages.charter.net/mkikstra/SolidWorks.html
for example:
NOTES:
1. Deburr all parts.
2. Mark parts per process spec STAR-101-a3.
<FlagNotes#NPer-Flag-3> Clean all parts using TMS-576 thinner.
4. Prime and paint per B7564-A-54 code.
any ideas how to accomplish this??? Thanks again,
For triangles I edit the note, go to beginning of note, add symbol from note "feature manager" at left, change symbol library to flag, then OK.
example:
Break all sharp edges.
"Break all sharp edges, surfaces, and seams."
