Moving dimensions
Moving dimensions
Hi all,
Can anyone tell me what variable I need to change (AutoCAD 2002). My problem is when I use the dimtedit command, only the figures move and leave the dimension lines and arrows behind. Also, I have set my dimension preferences for the text to be above the line but it still remains centered.
Thanks in advance for any help.
RE: Moving dimensions
DIMTMOVE set to 0 worked.
Haggis
