UNCOILER/COILER TENSION
I need to calculate the tension between a delector roll and a coiler. If the coiler is current controlled do I still need to consider the wrap angle.
I am developing a full middle on light gauge strip and I am wondering if my tension indication is accurate. Have checked roll set up for misalignment. Would appreciate any help
RE: UNCOILER/COILER TENSION
yindavies, I would strongly suggest that you refer your winder application to a system integrator that specializes in winders.  Constant tension winding is a rather complex subject with numerous subtleties that strongly impact the operating performance.
I've been doing drive/motor applications for over 15 years and, even today, refer wind/unwind applications to the specialists in the field.
A good integrator can make a wind/unwind stand work most excellently in a relatively short period of time where, after a huge amount of labor and time, inexperienced folks still will have very little in proper operation to show for their efforts.
You do need to consider the wrap angle, find the normal force on the tension meter (load cell I presume), and calibrate your reading accordingly.  I have found in the past that calibrated weights that are 75% of the load cell rating work nicely.
gcaudill is right, you should include your wrap angle to calculate the normal force.
 It is true that winders are involved and you need to understand the physics behind the process, on the other hand, it isn't rocket science and many of us taught ourselves by working with winder integrators and refining their applications.
