Linear Pattern Driven by part dmensions in an assembly
Hi.   I have a rectangular plate with Four parts that must be placed in the corners of the plate.  Actually I made four instances of that part and add mates to the plate, but I was wondering if there is any way to make a linear pattern of this parts along the edges of my plate and use the sketch dimension of it to control the distance in the pattern.  I mean, if I change the length of the plate, the distance in the pattern changes.  I Know about feature driven pattern, but there is no features in the plate to drive the assembly pattern.
Thank You for your help
RE: Linear Pattern Driven by part dmensions in an assembly
Yes you can. Use Equations to drive the Linear Pattern distances from the Rectangular plate dimensions.
eg:
"D3@LocalLPattern1"="Height@Sketch1@Rectangular Plate.Part"
"D4@LocalLPattern1"="Length@Sketch1@Rectangular Plate.Part"
If you are not familiar with Equations, you will need to read the SW Help files.
from (the City of) Barrie, Ontario.
Support bacteria - they're the only culture some people have
You insert a pattern in an assembly Insert\Component Pattern\Linear
SW04:
1) Show your Part dimensions that you want to use.
2) insert\Component Pattern\Linear
3) Under the direction click the dimension.
4) Pick a distance
5) Then the number of instances
6) Click OK
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
If you use Hole Wizard to create your holes in the plate first, you can use Component Pattern to place your hardware, and it will be associated with the holes should you move them.
Ray Reynolds
"Computers in the future may weigh no more than 1.5 tons."
Popular Mechanics, forecasting the relentless march of science, 1949
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
How about using a Design Table?
Ken
YEAH!   The selection of the dimension is exactly what I was looking for!
THank You Very Much!
Adi
Wrong!   I don't see the complete solution!  This one only pick the dimesion direction not the value....  mmmm I will try another proposition....
Adi
adicm
I don't understand your last post!
If you have created the Linear Pattern as per SBaughs first post, followed by the Equation usage per my post ... the inserted parts should follow the corner points of the rectangle when its size is changed.
