slide library
slide library
slide library
I have some trouble with viewing my slide library in acad 2000.  In the bhatch dialog box, I cannot see the slide preview of the hatch in the swatch window.  The problem is the same if I advance to the "..." dialog box next to the swatch window.  The hatching function works fine otherwise.  I can see the that the acad.slb file is not corrupted by viewing the slides from vslide command.  I use the exact same acad.pat and acad.slb on four machines, and I only have trouble on this one machine.
Any suggestions?
