how to import .prt to ideas???
how do i convert a .prt into ideas? I know i use the import option but which type of file it is. Any help would be great..
thanks
ant
thanks
ant
RE: how to import .prt to ideas???
Search back on previous threads, this has come up a few times before.
thanks
ant
If it's an I-DEAS .prt then through Manage Items, ie.
/ma it
Select Adopt (Bottom RHS)
Select a Project and Library to place it in and then select the file and press OK.
I want to thank you for you help... I will find out the orgins of this file first....if it is pro-e i will translate it to iges...
again thanks
ant
Pro/E parts usually have a .prt.# extension and contain text Pro/E in the file which you can search for in a text editor.
Michael
