Standard Drawing Notes Tip
Ever have a bunch of drawing notes that you often use?
Then to get quick access to them, simply make a new drawing (format is note important), and add your notes here.
Give this new drawing a name that places it at the top of a directory, like "0-notes.drw"
Now, when you create a drawing and need a standard note, select "EDIT / COPY FROM OTHER DRAWING..." and pick the "0-notes.drw", and then pick your notes from there.
Steve
http://www.sprdesign.com
RE: Standard Drawing Notes Tip
We just store all common stuff in Word then Copy/Paste them in when/where required.
Hope this helps.
maybe only a drafter
but the best user at this company!
It's just that you can't keep and text formating using Word.
Hi All,
We use the pro_note_dir in the config.pro to go to a known location when you use create note from file.  You can save many different notes for different apps.
Tofflemire
