Simple Linear Motion?
I'm building a bench top reactor setup and I'd like to have my reactors oscillate up and down in a temperature bath. Does anyone know, specifically, what I can use that's simple/inexpensive to set up and will create continuous push/pull motion (mounted vertically)?
I need a stroke of about 5.5" and a slow speed (less than 1"/second). The load I have is about 5-6 lbs, not much. I've looked at several things - linear slides, motors, actuators - but I'm just not familiar enough to know what to choose.
I'd appreciate any help along the lines of what exactly I need to look for, where, how to configure, etc. if anyone can offer it.
Thanks!
Thanks!
RE: Simple Linear Motion?
Hope this helps.
saxon
Ray Reynolds
"Computers in the future may weigh no more than 1.5 tons."
Popular Mechanics, forecasting the relentless march of science, 1949
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
ChemE, M.E. EIT
"The only constant in life is change." -Bruce Lee
rmw
If we make a quick calc of your power requierements we find:
Load: 6 lbs
Speed: 1"/sec = 60"/min = 5'/min or 5 fpm
Then you requiere: 6 lbs x 5 fpm = 30 lb-ft/min
Since 1 HP = 33,000 lb-ft/min then we have:
30 ft-lb/min / 33,000 lb-ft/min = 1/1000 HP net power use so you will find that almost the smalest motor-reducer combination that turns a crank with 2.75" excentricity will do the work for you.
As a crank that gives you the 5.5" stroke will move 11" in one revolution (5.5" down + 5.5" up) and you want a linear speed of 1"/sec then you have 11 sec/rev which gives you about 5.5 RPM output speed for your reducer with an input power of 1/1000 HP.
Since the power involved is so little you might get along with a simple disk attached to the output shaft of the reducer a journal drilled and tapped to the disk (a simple 3/8" NC bolt should do) with a rod that should be about 16" long and a 6" slider so the swinging motion of the rod is turned into a simple linear motion. Any small shop should have the facilities for making such a device and should be cheap also.
Cheers
SACEM1
JP
<nbucska@pcperipherals DOT com> subj: eng-tips
It is a simple ___--___ crank.
m777182
