untrim surface
untrim surface
In Mechanical Desktop, it has command untrim surface. It changes the trim surface back to it basic surface. The basic surface of the trim surface usually has rectangle border. Does Catia have the equivalent function to do it.
RE: untrim surface
So, to answer your question: a untrim command is not necessary in CATIA V5.
RE: untrim surface
In GSD you will find behind the Join... the Untrim fuction. It works.
Eric N.
catiav5@softhome.net
RE: untrim surface
Thanks itsmyjob(Mechanical) I am new to Catia(2 weeks). I don't know about GSD.
RE: untrim surface
