Hydrostatic pressure rise
I am interested in knowing how to estimate or calculate the expected pressure rise in a closed pipe full of liquid propane or butane (initially pressurised well above its vapour pressure of course) when it is heated. My particular case at the moment is a length of 32mm nom. bore steel pipe, about 15 mtrs long, filled with liquid butane at 900kPag. If it is initially at say 25deg C, what would be the expected pressure rise when heated to 45deg C. Obviously being an incompressible fluid the usual gas laws do not apply, but the pressure DOES rise very sharply. Any help would be appreciated.
Rod
Rod
RE: Hydrostatic pressure rise
The pressure rise is usually so severe that only a very few °C temperature rise will be sufficient to blow a gasket somewhere in the system. Therefore, a thermal relief valve or expansion chamber (accumulator) is usually installed to protect any section of pipe that can be blocked in full of liquid.
If the pipe is full of a 2 phase (liquid/vapor) mixture, then your answer is correct. However, if the pipe is 100% full of liquid, then there is no additional space for any of the liquid to expand into vapor. This is when the severe pressure rise can occur, likely leading to a leak somewhere in the system. This is true not only for hydrocarbons, but any liquid.
Butelja speaks of accumulators. Are those accumulators specialy designed for this service or are they "general" purpose accumulators?
Does anybody know links to manufacturing companies? Or has anyone more info on this subject??
Grtz
Ben
http://www.flexicraft.com/index.asp
http://www.metalbellows.com/
For noncritical and/or noncorrosive applications, an elastomer bellows may be more cost effective.
beta = rho'/rho*dT)
beta is the cubical coefficient of expansion
rho' is the change in density between two temperatures
rho is the initial density
dT is the change in temperature.
For the density, I used the PVT data for ammonia in Perry's.
I got a beta of 0.0014 per deg F. I also checked the approach for water (which is commonly available) and got virtually the same number as what I've seen published, 0.0001 per deg F.
beta = rho'/(rho*dT)
I have not yet found anything on the expansion of ammonia. I have been searching for days. I really need to get something so I can get my spreadsheet finished. I have found several different values for the density of liquid ammonia, can't really find an answer on the speed of sound of ammonia, and the k-value for the worksheet isn't quite working out. anyone got any help!?!?!?
Normally, if a blocked in liquid having total volume of in excess of 500 l, then a thermal relief valve, TRV (size is normally 3/4" by 1" or sometime 1" x 1" though it is quite rate using this size) is required. The set pressure of TRV is maximum flange design pressure (MAWP/Design pressure) plus 20 %. Refer to B31.3 about this. Though sometime, the set point is the same with flange design pressure based on ANSI B16.5.
Based on previous experience and calculation, every 1 deg C increase in fluid inside temp, a pressure rise of 100 psi is expected. The calculation of pressure rise is independent of fluid volume as hilited by Butelja. It does depend on the behaviour of the fluid (cubical expansion), properties of pipe.
Another option of not having a TRV is by installing a permanent drilled check valve of small bypass of the block valve so that the rise in pressure within the block-in liquid can be expelled to the other reservoir/system/piping.
TRV is normally discharge back to the tankage of to the open/closed drain system. It can also be cascaded to the next line provided the TRV is installed and finally discharge back to the tankage.
I've a MS Excel spreadsheet for this calculation.
Hope this help.
There was a rupture on one of PDO's flowlines. The flowline was "blocked in" at appropriate places, along the length of the pipeline to repair the damaged portion of the flowline.
The blocked in section of the pipeline(6" API 5LX42)is about 4 km. in length carrying crude (High GOR about 1000, 25% BS&W) of API 38 density. The initial temperature of the crude (at the time when the pipeline was blocked) was 18 Deg.C
I am required to estimate the final pressure rise and the eventual pressure of the pipeline if the temperature of the blocked in section reaches a temperature of 40 Deg. C.
It is estimated that this pipeline will stay blocked for about 9 hrs during the daytime before the rupture is taken care of and flowline is "up and running".
Please suggest solutions on how to work this problem out.
I would take a first pass look at it by estimating the amount of gas/liquid you have when it is initially blocked in at 18C. You'll need to have a process simulator or some tool to estimate the amount of gas at this temperature and the initial pressure.
Then, restimate the amount of gas at 45C. The change in liquid volume in this case should be minor. You can put the additional gas into the vapor phase and see what the pressure is. As the increase in pressure will affect the amount of vapor released, it will be a trial and error solution.
You should be able to also do a quick check of the 40C final figure. You know the surface area of the pipeline that can 'see' the sun and the radiation from the sun (likely close to 350 BTU/hr/ft2 there). Work out how much heat that is, look at the mass of the pipeline and its contents and see what the dT is for 9 hours. You can also consider heat convection/conduction from the surroundings if that could be significant.
I know this is really late, if you haven't gotten the data you are looking for, densities of ammonia can be gotten from Perry's handbook for Chemical engineering or the ASHRAE series.
I am curious to know if the the pipe diameter/thickness ratio is used to calculate the change in pipe diameter due to internal pressure.
If you ignore changes in pipe geometry, this problem can be solved by following a line of constant liquid density from the inital T&P to the final T. Graphs of liquid density as a function of T&P are available for propane and NH3 from ASHRAE.
If you account for thermal expansion of the pipe, the radius and length of the pipe drop out when you divide the initial volume by the final volume.
I agree with your explanation. However, I prefer use 90% of the ANSI B16.5 as a security factor.
Can you send me your spreadsheet for TRV calculation ??
Thanks a lot !
