Washers for SS fasteners
I am specing ASTM F593 Group 1 Alloy 304 bolts and ASTM F594 Group 1 Alloy 304 nuts. The nominal diametre is 3/4", and they are being used as anchor bolts for railing in a marine environment.
I cannot find an ASTM citation for standard or plate washers to use with these fasteners. Any ideas?
Thanks for your expertise!
RE: Washers for SS fasteners
Cory
"Galling can also be reduced by using two different stainless steels, of significantly different hardnesses, on the mating surfaces. A Brinell hardness difference of 50HB may overcome galling.
A common belief that the use of grade 316 studs with grade 304 nuts (or vice versa) will avoid galling is a myth (there is no notable difference in galling)."
http://www.assda.asn.au/asp/index.asp?pgid=18732
rmw
You might consider the MS 15795 washer series. I am not aware of any ASTM stainless washer specs, but the above stainless steel washer military specification might be useful.
I'm not sure galling will be an issue, as the fastener will not be removed frequently (if ever). I would use a harder stud than nut, if this is an issue -- but I'm trying to find relatively common fasteners for this application.
Regards, RAF
