Peel test for Incoming Inspection
I am searching for verbiage that will specify a performance test that receiving inspectors can perform in a non-conspicuous area to check for paint adhesion. Perhaps an "X" cut into the substrate followed by a standard cellophane tape applied and peeled back. May I hear from you if you have specified this on a drawing?
RE: Peel test for Incoming Inspection
