Global Interference Check
Does anyone know how to run a global interference check?
I'm sick of having to click on each and every part in my assembly every time I want to check it.
I'm using v11.
Chris
RE: Global Interference Check
There is a parameters tab in the Ribbon Bar that you set for what consitutes selection set 1 and 2.  In there should be a setting to do a global check.  I haven't used v11 for quite some time, but I think it was in there and not something new to v12 and on.
--Scott
For some pleasure reading, try FAQ731-376
