Add-In to highlight entire row/column of selected cell in Excel?
3
Anyone know of an Add-In (or something else) for Excel that will highlight entire row and column of selected cell, instead of just the row and column headers?  I think I saw this in Lotus.  It'd be nice to have that feature in Excel.  I wrote a macro to do it, but the only way to highlight the rows and columns I could think of was to select them...and then that mess's with which cell is selected because they're all selected...and when I hit the Delete key, *all* those cells were deleted :(
Thanks for your time,
Ken
RE: Add-In to highlight entire row/column of selected cell in Excel?
You can use conditional formating features and specify following two conditions, for entire sheet cells, with appropriate cell format
Condition 1
Formula Is =ROW()=activerow()
Condition 2
Formula Is =Column()=activecol()
whre ActiveRow and ActiveCol are two functions defined in a module as
Function ActiveRow()
ActiveRow = ActiveCell.Row
End Function
Function ActiveCol()
ActiveCol = ActiveCell.Column
End Function
To apply this formating each time you select a cell write following code in SelectionChange event of the worksheet as
Private Sub Worksheet_SelectionChange(ByVal Target As Range)
ActiveCell.Calculate
End Sub
This however will suppress your existing cell formats temporarily when highlighting the row and column
I can give you the sample if required
Hope this will help
The method above forces excel to execute a macro every time you move the cursor. It means no UNDO or even COPY command will be available... Too much of a price to pay... Once I wrote the following routine for company timesheet:
Private Sub Worksheet_SelectionChange(ByVal Target As Excel.Range)
Dim irow%
On Error Resume Next
irow = Target.row
Range("A1:T40").Interior.ColorIndex = xlNone
Cells(irow, 2).Resize(1, 19).Interior.ColorIndex = 36
End Sub
It does the work, but disadvantages I described still apply.
No these disadvantages are not there. However, I would be better to modify the code as under
Dim WinState, MyWin As Window
ActCol = Target.Column
ActRow = Target.Row
Set MyWin = ThisWorkbook.Windows(1)
Application.ScreenUpdating = False
WinState = MyWin.WindowState
MyWin.WindowState = xlMinimized
MyWin.WindowState = WinState
Application.ScreenUpdating = True
End Sub
Public ActCol, ActRow
ActiveRow = ActRow
End Function
ActiveCol = ActCol
End Function
A sample can be downloaded from
http://home.ripway.com/2004-6/135145/Public/HighlightSelectedRowColumn.xls
In both the original code and modified code, the COPY and UNDO features are available
Thanks! Your code works great, undo and copy command work as well. The only complain, the windows blink performing Application.ScreenUpdate.
tmukhtar,
Thanks!  I'll give it a try.
Ken
tmukhtar: The XLS url no longer works, could you re-post it somewhere please?
Eric
all,
you really do not need to write vba code to highlight or shade alternate rows. note the tip from the following website:
http://www.j-walk.com/ss/excel/usertips/tip043.htm
good luck!
-pmover
Whoops PMover,
I think you missed the concept. We are trying to highlight a cell, column, row, etc... when another cell is selected.
For me, I created a vacation calendar with dates going down the left and people's names across the top.  When a person selects a cell somewhere in the middle of the spreadsheet, I want the name cell on the top and the date cell on the left to be selected to show where they are (like an X Y coordinate).  In the example below, the person clicked on the cell under Bob and on January 3rd, I would like Bob's name to highlight and January 3rd to highlight.
       Eric  Sally  BOB  Robert Pam  Mary   ....
jan 1
jan 2
JAN 3               XXX
jan 4
jan 5
After a while last night, I WAS able to use tmukhtar example and get it working.  When I get home tonight, I'll post my implementation of his code for others to reference.
Eric
thanks Eric! whoops is right . . . i oft glance over text (reading too much at times) and not read the details. shame on me . . .
thanks again!
-pmover
You can also try:
Union(ActiveCell.EntireRow, ActiveCell.EntireColumn).Select
TTFN
This code is the same concept but does not need conditional formatting.
    If Len(ActCol) > 0 Then         'Not first time in worksheet
       Cells(ActRow, ActCol).EntireRow.Interior.ColorIndex = xlColorIndexNone
       Cells(ActRow, ActCol).EntireColumn.Interior.ColorIndex = xlColorIndexNone
    Else                            'First time in worksheet
       Range("A1:IV65536").Interior.ColorIndex = xlColorIndexNone  'Clear colorindex of entire worksheet
    End If
    ActRow = Target.Row
    Cells(ActRow, ActCol).EntireRow.Interior.ColorIndex = 19    '19 is light yellow
    Cells(ActRow, ActCol).EntireColumn.Interior.ColorIndex = 19
End Sub
Simplification of above post.  Also, when using code from first post, I was getting slow response once I updated data in a cell.  This approach does not use conditional formatting and does not affect the speed after updates.  Also it does not require a separate module for the ActRow and ActCol public variables:
    'Clear interior color for entire worksheet
    'Set row/column interior color
    Cells(Target.Row, Target.Column).EntireRow.Interior.ColorIndex = 19    '19 is light yellow
    Cells(Target.Row, Target.Column).EntireColumn.Interior.ColorIndex = 19
End Sub
Simplification of above post.  Also, when using code from first post, I was getting slow response once I updated data in a cell.  This approach does not use conditional formatting and does not affect the speed after updates:
End Sub
Last post on 22 Aug 05 14:03 by bfrkhjk works but prevents copying from one cell and pasting to another.
Two alternatives
1. Use script from 22-AUG and copy the value from the forumla entry (or double-click cell, drag mouse over values, press ctrl-c) which uses Windows copy instead of Excel cell copy.
2. Modify script as below.  With this, you need to press ESC to get out of Excel copy mode:
    If Application.CutCopyMode Then
    Else
    End If
End Sub
