Acoustic Absorption Materials
I am currently doing a project in which I measure acoustic levels in a test tank using a hydrophone, and possibly develop the system for offshore applications. The hydrophone chosen will be connected to a beacon housing and have as near as possible 360 degree vision and has a frequency range of 1 Hz to 100 kHz. So that acoustic waves are not reflected back off the housing affecting the hydrophone's readings it is thought a conical shaped end cap made of an acoustic absorbing material could be used to absorb these.
I would like to know if any one knows any suitable materials for this application and who manufactures them?
Cheers
Cheers
RE: Acoustic Absorption Materials
You'd be better off developing an algorithm to deal with any reflections off the housing that do occur.
Cheers
Greg Locock
