Sizing Servo Motor for Variable Torque Application
What I've got is a regulation problem.
I need my motor to be able to reject disturbances by provide a variable torque onto one link of my robotic arm.
I can obtain a closed-loop time based torque profile of the load for any initial condition and can also obtain the torque profile at the motor shaft through my gearbox.
I need to size a motor capable of producing variable torques as required. So far, I am working with worst case scenarios. I've deduced the maximum instantenous torque, which coincides with the maximum permissible initial disturbance. For optimum performance, I'm thinking of using a motor whoes midrange torque matches the maximum instantenous torque required for my application.
Is this a proper way to select a servo motor? Besides current limitations of the servo-amp, are there any other constraints I should be considering when selecting the motor?
This is my first sizing exercise.
TIA.
TIA.
RE: Sizing Servo Motor for Variable Torque Application
Barry1961
