Thin adhesive insulation 3/5mm to stick one face on steel sheet
I would like to find :
Thin insulation adhesive 3 to 5mm can be sticked one face after taking out protective paper to steel sheet.
Width 0.80 m to 1.20mm
Product searched is : foam + external vapor barier similar a aluminium foild
Used mainly for cutting sun effect and noise on metallic building roof
Product most be flexible, delivery in rolls
If somebody can help me it will be great and will help people living in "ranchitos"which are covering by steel sheets
We have aid programs in Dominican Republic & Haiti
RE: Thin adhesive insulation 3/5mm to stick one face on steel sheet
Have you considered 3M VHB tape?  Your posting says the width will be .8m to 1.2 mm, or 1.2 mm to 800 mm.  That is a wide range.  What temperature range?
Thanks for your answer, I do not know product mentionned of 3M. "can help us to find it?"
Yes we need from 0.8 Meter to 1.2 corresponding to panel size on metallic building "roofing"
Temperature on panel can reach 70°C
Process to apply the insulation:
1)We stick insulation on flat sheet
2)We profile the sheet
Best regards
