Load sharing factor in timber design
I am carrying out an AASHTO timber dock design and want to make use of the load sharing factor (1.15). Please advise what the requirements are for making use of this factor. I am working in the UK and unable to obtain a copy of AASHTO at present. (i.e. I plan to space 6 no. stringers on 10 foot span - 21", I believe this is adequate but need confirmation and explanation).
RE: Load sharing factor in timber design
http://www.fs.fed.us/na/wit/
trail bridge catalog:
http://www.fs.fed.us/na/wit/WITPages/bri...
free publication on Timber Bridges: Design, Construction, Inspection and Maintenance:
http://spfnic.fs.fed.us/wit/WITpubs/Pubs...
- minimum of 4 members at centres < 610mm
- adequate provision made for lateral distribution via purlins, binders, boards or battens.
The BS code only permits a factor of 1.1 for load sharing but the load sharing criteria should be similar.
