Changed Colors
Changed Colors
Can someone please help me change my dimension colors and my sketch entities back to black and gray. This problem is only in drawings. The dimensions have turned to red and the sketch entities are now dark red. This all happened after I used the task scheduler to try to predefine some drawing views in order to automate drawing creation. These changes are in new drawings as well as ones that were already drawn in the prefered color black. Any help would be appreciated.
RE: Changed Colors
Did you try the "Tools" "Options" "Colors" Dimensions? There's about 5 options in there for dimension colors.
I hope this helps,
macduff
RE: Changed Colors
RE: Changed Colors
Scott Baugh, CSWP
to me
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
RE: Changed Colors
macduff
Happy Un-Birthday to me
RE: Changed Colors
RE: Changed Colors
I also drew a part with no relationships or dimensions, made a drawing out of it and dimensioned it and wala! red dimensions
RE: Changed Colors
RE: Changed Colors
RE: Changed Colors
If that does not work ... try doing a SW repair ... check the FAQ section for helpful tips on repairing.
Good luck.
RE: Changed Colors
RE: Changed Colors
Reset All
Scott Baugh, CSWP
to me
RE: Changed Colors
RE: Changed Colors
Scott Baugh, CSWP
