defpoints PROBLEM
defpoints PROBLEM
defpoints PROBLEM
Once in a while, after placing an entity on the defpoints layer, I cannot select that object anymore, as if it didn't exist. This is not a constant problem though. Is there a variable I'm missing here to account for that?
RE: defpoints PROBLEM
Hi SouthernDrafter,
Defpoints is closely related to layer 0 so that if 0 is locked or frozen, then objects on defpoints are not selectable.
Lothar
ADT 2004
ACAD 2002
That's probably it. Seems I read that some while back, and just forgot! Thanks Lothar- you're a smart one!
