Need help to draw a spiral...INV 8
I have a process in which I roll up a sheet of copper. Can anyone help me as to how to draw the sketch for a profile to extrude along. Or if this is the right way to do it?
Thanks in advance..
Thanks in advance..
RE: Need help to draw a spiral...INV 8
If the part turns out to be too large to deal with in an assembly, you could also make a solid cylinder and attach a texture to each end to make it look like a coil (just like the thread texture on bolts)
