PDM2004 VS SW2003
PDM2004 VS SW2003
PDM2004 VS SW2003
is it possible to do this?
I  want to install 2 windows on a computer .
Then install a sw2003 on on of them,and sw2004 on another.
I need to use pdmworks on both contecting just 1 vault, so it seems i have to install vault service 2004 and then I must install pdmworks2004 on sw2003 , so what's the solution ?
RE: PDM2004 VS SW2003
You need to run PDMworks and SW utilizing all the same versions. This comes down directly from SW.
You can't run TB using 2 different versions of SW. Heck you have to be using the same SP as well.
Scott Baugh, CSWP to me
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If your in the SW Forum Check out the FAQs Forum559
To make the Best of Eng-Tips Forums FAQ731-376
