torque wrench
torque wrench
Hi i'm designing a torque wrench. But i need some help.
the gear connects to the socket. If i'm putting 300ft/lb torque on a nut using the socket connected to the gear. and the gear connection to the handl thru the gear locker, and the gear locker can push against the weight. Will the gear locker push against the weight with 300ft/lb? the weight is actually a sensor. I want the sensor to be able to sense that there is 300ft/lb of torque being exerted on the nut
Now my second drawing torque2.jpg uses a spring like a normal torque wrench.
at the end of the handle there will be a dial that will tighten and losen the spring which pushes against the gear locker, which in turn keeps the gear connected to the handle. say i put the wrench of 150lb/ft torque using the dial, then the spring pushes the gear locker with enough force to keep it connected up to 150lb/ft torque, if it goes over, the gear's teeth push the locker and spring back and it disconnects form the handle.
how would i calculate the spiring tension, etc to get this working. Can someone give me links, leading me to the right direction.
Pictures can be foudn here http://gainguy.unixserver2.com/torque3.JPG http://gainguy.unixserver2.com/torque2.JPG
Thanks for any answers.
RE: torque wrench
To measure torque you have to have some kinda arm, acting against a scale of sorts. And if the radius of the arm changes at all that will affect the accuracy of the reading.
RE: torque wrench
this is the real image
thanks
p.s. this forum really needs an edit button
RE: torque wrench
This forum has a preview button. I suggest you avail yourself of this option.
Best regards,
Matthew Ian Loew
"I don't grow up. In me is the small child of my early days" -- M.C. Escher
RE: torque wrench
RE: torque wrench
The force at the point of contact will be roughly (?exactly?) normal to the tangent between the two contacting surfaces.
I imagine a good read of Shigley would be appropriate, this is a rather basic problem.
Cheers
Greg Locock
