Maximum Number of Mates in a SW Assembly file
I was wondering what everyone uses as a good general guideline for the maximum total number of mates to have in an assembly file.  I read in one thread where someone's VAR recommends trying to stay under 300.
It seems obvious that less is better but I am interested in feedback on the subject.
Chris Gervais
Sr. Mechanical Designer
Lytron Corp.
RE: Maximum Number of Mates in a SW Assembly file
Keep your Top level mates under 300.
With parts or sub-assemblies in an assembly. I figure about 2 at least if not 3 mates to fully define (not always) per part or sub.
If you use more Sub-assemblies instead of parts, that will bring your number of top level mates down to a lower number.
Scott Baugh, CSWP to me
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If your in the SW Forum Check out the FAQs Forum559
To make the Best of Eng-Tips Forums FAQ731-376
RawheadRex (Mechanical)
Hi Scott,
Thanks for the input.  Another question if I may:
Is the 300 number something recommended to us by SW or is it more of a defacto standard based on the current prevailing wisdom?
Chris Gervais
Lytron Corp.
