Bluebeam/Solidworks Crashing
FYI We are running SW 2004 and full blown Bluebeam. If we change a configuration, saved, and closed a file in SW we would crash 100% of the time. When we turned off Bluebeam in the addin menu the problem went away.
RE: Bluebeam/Solidworks Crashing
I have lots of customers that use both pieces of Software and I have not from any of them. So your problem my local to and your company.
What have you tried to do to fix the problem?
Scott Baugh, CSWP
to me
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If your in the SW Forum Check out the FAQs Forum559
To make the Best of Eng-Tips Forums FAQ731-376
What he's talking about is the full blown version of Bluebeam. The PDF you and I have is the free bluebeam PDF that is built into SW. You can buy a pushbutton PDF version from Bluebeam. www.bluebeam.com
Scott Baugh, CSWP
to me
Not all solutions falls into one of your "Cookie Cutter" solutions to all problems. This was a big problem to us! I thought we may actually be able to help someone who is experiencing the same symptoms.
Have you heard any more regarding this problem? I have recently upgraded to SW2004 sp4.1 and Bluebeam 2.2.8 and this problem still ocurs.
Anyone know if this problem has been fixed in SW2005?
I don't know if they have fixed it or not. We print using an API call rather than thru Bluebeam. I got around the problem by loading bluebeam - making the PDF - and then unload Bluebeam all within the api call. We have an intranet image system and we have to pass custom property info as well as the PDF to the system, hence the api call.
I am running SW2004 sp3.0 and can not save as pdf...I use the Acrobat distiller to create pdf's through the print function. Is there a solution out there to this problem besides an API call?
SWCADMAN
