Lockfiles and backups - no good
Hi all.
We are working on Inv. 8 using semi-isolated multi-user projects (with Check-out / Check in), and we are having a problem making live backups.
When we use Windows Explorer to copy and paste all our work ( .ipt, .iam, .idw etc.) to a removable hard drive, we get the following message:
"Error: lockfile.lck - Portions of this file are busy or in use by another process"
This stops the copy operation, and thus the backup, dead in its tracks. The files are hidden, I believe, because they do not appear in the folders. We would like to exclude them manually if possible from the backup set, or we might have to go to a "backup" program, which I'm not too crazy about, given the format of the backup data.
Any help would be appreciated.
tg
tg
