can microwave be focused?
I am considering to use focused microwave energy to heat ceramics materials?I don't want to put the ceramics in oven, instead i want to put it in open space.Is this idea possible.
Tks,
Tks,
RE: can microwave be focused?
> You'll consume way more energy, as you cannot take advantage of a resonant cavity
> You'll be spraying microwave energy all over the place, which you and your co-workers might find a bit annoying
> You'll probably cause massive interference with electronic devices within a 2 mile radius
TTFN
You would then need absorbers surrounding the setup to stop the beam killing birds, people and other living things in the area.
Best Regards,
A 6-ft dish has an diffraction spot spread of about 9.4 degrees.
TTFN
It worked pretty well, our next step was to create a smaller hot spot using a ceramic dielectric filled elliptical antenna, though our funding ran away from us (literally, it was inappropriated by a scoundrel co-worker).
kch
http://www.talisman.org/~erlkonig/misc/microwave-m...
cotton, wool, or leather clothing. NO Synthetic clothes.
No cuffs on your pant legs
Leather boots INSIDE of pant legs
eye protection
leather welders gloves.
Many metals give off poisonous gasses when melted, such as lead, zinc, mercury, etc. Beware.
Interested in focusing 2.4 Ghz uwave for materials processing as well. Saw response from Higgler that begs the related question: can one deliver 2.4 Ghz uwave energy, say starting from an ordinary oven waveguide, by flexible cable (RG8??) to some sort of applicator, say an antenna/horn/dish such that ~1 kw or so of energy is directed to a dielectric workpiece for heating?
Such technology is not in common literature but I haven't seen any such arrangement so guess it's not feasible?? Is principle ok but needs tweak?
Also, watch out for the HIGH VOLTAGE at the klystron. In today's world of transistors and IC's, most people no longer know how to work with high voltage. Find some safety tips somewhere. What I can remember: Don't wear any jewlery, especially rings. When testing, keep one hand in you pants pocket. If you want to work on the circuitry, take a long screwdriver with a plastic handle, ground the screwdriver to the chasis with an aligator clip/wire, and discharge the high voltage capacitor terminals! Do this even if the project has been sitting around for weeks unused (the blead off resistors sometimes fail and you have a lethal voltage on the capacitor).
Also, nobody has answered the fundamental question: how do you prevent damage to your eyes when experimenting? I would imagine there is a big chance for developing cataracts.
I have some expertise working with electronics including HV, digital, x-ray equipment etc. just not uwave RF of this power and my E&M classes don't help understanding waveguides vs. coax vs. antennas.
I plan to use a commercial magnetron with adjustable power so experiments can be done at low power first. With added confidence, I may just tie into a cheap oven waveguide. Will see where ham literature takes me. Thanks.
TTFN
a low power magnetron, that will be a real first....only on eng-tips
if you find out how to do it you better register the patent,
there are other more controllable sources.
highly recommend use of special grounding equipment to discharge the caps...screw drivers are not considered adequate safety equipment
Thread247-93662
Also check the web - here is an industrial microwave heating industry that does a lot more than food, and there may be application papers out there.
I saw the hot dog thread and mentally smirk. I can't see how it can be done with one cycle because the material properties are so different. I can see someone making a flexible reflector tied to a multipower source such that a good focussed zap will heat the dog and after it's warmed up, defocus and reduce power for the bun/bread combo.
I am trying to heat materials up to 1200 C. It can be done and is not a secret, but my need is not merely to being a box on the factory floor, rather to direct the energy to a target and perhaps focus it a little to raise flux. Wavelength can be anywhere, 1-100 GHz, but cheap tests are clearly best at 2.45
