decarburization at stress concentrated zone
Hi all,
I have a part made of AISI 8620, it's hot forged and then go for carburizing process. I notice some stress concentrated zone (at right angle corners especially), are found to have appreciably lower carbon content than it intrinsic level. How can this happen?
Best regards,
ct
RE: decarburization at stress concentrated zone
Geometry effects the rate of carburization - in gear teeth for example it is typical to get only about 2/3 the case depth in the root compared to the mid-tooth area.
What process are you using to carburize the parts?
A little more information might help someone resolve you problem.
