PCB Mechanical Design Guidelines
I'm a mechanical engineer and have the job of "designing" the mechanical characteristics of a PCB.
Question: Where can I find some guidelines about that matters, ie suggested minimum distance between connectors, distance between assy screws, type of screws to use, number of screws to use, placement of these screws, prefered PCB sizes by manufacturer, etc, etc, etc...
Etienne Fortin
Sensio
Etienne Fortin
Sensio
RE: PCB Mechanical Design Guidelines
These documents won't give you all the answers- they are merely guidelines and will most likely point you in the right direction. Much of it is still left up to you, the designer, to work out.
D. Steinberg, Vibration Analysis for Electronic Equipment.
Tom Irvine
www.vibrationdata.com
