SO2 scrubber for Diesel Engine
Is there a cheap scrubber for a Diesel Engine.
The unit is stationary, has Biogass as a fuel source.  What I am looking for is something to put on the stack to scrub the SO2 out.
Any Ideas?
RE: SO2 scrubber for Diesel Engine
If you have a source, and sink, of seawater available, this might work:
http://www.dmeinternational.com/marineexhaust/default.html
I have no idea if it will work with fresh water.
I don't think I've ever seen scrubbers advertised as 'cheap'.  When you scrub a stream of dirty hot gas, you end up with a stream of cleaner gas, and several streams of stuff that you don't particularly want.  Sometimes you can turn it into something you can sell, if you're working on a scale that's large enough.
Mike Halloran
http://www.deangelomarine.com
