NaOCl vs. Inconel X750
What kind of corrosion rate will I experience using an Inconel X750 spring in 14-16% sodium hypochlorite?  The solution is being injected through a ball check made of HC-276 with a ceramic ball.  I don't expect there will be any aeration.  The Hastelloy and the ceramic are fine but I am not sure about the spring.
RE: NaOCl vs. Inconel X750
What is the temperature of the solution?
The Inconel X-750 exhibits superior resistance to chloride induced SCC.
The following thread may be of interest to you;
Thread338-95535
