Piping flange thickness design.
I am currently doing some work with titanium pipe (large diameters), how can I calculate the thickness of the flanges that I need to use on pipes of 3" to 12" diameter?
Piping flange thickness design.Piping flange thickness design.(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Piping flange thickness design.
If you have any trouble getting the information then email me.
I disagree with the above comments. The methods referenced are for custom designs of vessels, which, I do not believe you are really interested in....
You must tell us the design pressure and temperature of the system !!!
First, please note that this is not large pipe...... 3 inch NPS to 12 inch NPS titanium pipe is very common in the pulp and paper industry. There are standard industry pipe flanges that are used for this pipe that are very economical.
Secondly, I am assuming you are dealing with modest pressures and thin walled piping (Schedule 5S or 10S)........ Commonly, these systems are joined with "lap-joint flanges" ( also called Van Stone Flanges) and cheaper carbon steel backup rings. The premium material, titanium in your case, is the only material to touch the fluid.
Try contacting the Felker Bros 800-826-2304 or see the www.petropages.com website.
Also try the Flowline Corp, in Newcastle, PA on 412.658.3711 for more info on these flanges.....
Good Luck !!!! MJC
Cheers
Babu
PV Engineer
Singapore
