View dwg files in a VB form
I would like to view dwg files (AutoCAD) in a VB form. Does anyone know of a plug-in or other method?
RE: View dwg files in a VB form
http://www.cadsofttools.com/?PageName=ABViewer
Good Luck
johnwm
________________________________________________________
To get the best from these forums read FAQ731-376 before posting
http://www.infograph.com/products/dwgviewer/DWGdownload2.asp
It used to contain an activeX component to display dwg's and dxf's in your VB programme (invisoX)
For what its worth you can display 3D wireframe using a Java applet from
http://www.escape.de/users/quincunx/dxfviewer/index.html
But this might not be of much use.
Can you stitch Java applets into a VB program? or maybe call up a HTML page containing the applet in IE from your VB program?
