Cyclic Loading in Ansys
Hello friends,
Could you guys help me with this analysis.
I want to simulate cyclic loading on a small cylindical hollow part with 2 symmetrical holes on its surface at the centre of the part. I want to constrain in all directions at one end and subject the other end to 50N in tension and 50N in compression(50N in tension in 1 cycle and 50N compression in next cycle). I want to figure out the life of the part subjected to such loading. Please let me know if this can be done in Ansys or Workbench? which would be preferable and wat kinda inputs i need for doin this. It would be of great help if someone can tell me if there is similar example solved in ansys?
Thank you in advance....awaiting ur replies....
Harid
