Rust prevention on metal tooling.
I am trying to find something that I can put on metal fixtures that will prevent rust on them during storge. We store all our fixtures in a controlled atmosphere room, and we are still getting rust on them. If anyone has any ideas on how we can stop this from happening please let me know?
RE: Rust prevention on metal tooling.
Then look up Rust Preventative, VCI, oil coatings, bearing coatings, etc
There are a lot of vendors out there that would probably love to give you a demo on their rust prevention products.
Most products out there (that will give you a long shelf life) will probably need to be removed before using the fixture. In my experience, most alkaline cleaners will remove the oil and residue. Most likely the vendor will be able to tell you what will work the best.
Not knowing exactly the kind of fixtures you are using, I might also suggest doing the same as tool and die shops and dip your fixtures in a heated wax or rubber like substance which coats the metal and is easily removed.The size of your fixture and any orifices may be a problem however.
Thank you
we store metal parts in a most curious manner.
1. Wipe down with vinigar.
2. wipe down with ordinary liquid floor wax .
3. remove wax when and if required , with floor wax stripper and soapy water .
You can skip the vinigar wash on nonferrous metals .
1. What is material of your fixture
2. Which kind of coating exists on fixtures (if any)
Controlled atmosphere will not help by itself. Even slightest amount of humidity is sufficiant to cause corrosion. Theory even says that corrosion is developing more in low humidity-atmosphere (if you put metal in pure water, most corrosion will exist on border zone, not in the water - talking about water without salinity).
If you store ordinary low-carbon construction steel without any protection - try with commercial "primers". You can buy primer and cleaner together: apply primer during storage, clean with cleaner before use. There is also possibility to simply add layers of other coating compactible with primer. Chemical stores related to construction supplies know everything about that.
Live Aloha
You can get short term or long term rust protection.
Crown brand or Slide brand can be found here.
Good luck.
