Caculations for evaporator and condensor tube lengths?
Hello everyone,
I am fairly new to the field, and helping with the design of the refrigeration for freezers used for commercial use. These are fairly simple freezers and not large at all. Basically used in corner stores throughout North America to freeze ice cream.
What my problem is, I’m guessing at the evaporator and condenser lengths and adjusting accordingly. This obviously takes time, and I was wondering what the calculations would be to properly figure out these lengths accurately? Where could I locate this information, and is there any software available for it as well?
Aaron
Aaron
RE: Caculations for evaporator and condensor tube lengths?
Mike
The units are fairly simple. The refrigerant (R-134a) starts off in the compressor moves to the condenser (3/16”), then to a filter dryer, where it then passes through a cap-tube (.031”) and into the evaporator (1/ 4”), then back into the compressor.
Any help in figuring out the evaporator and condenser lengths would be appreciated.
Mike
Also, are you not using any fan to move the air? If you are using a fan, what's the CFM/FPM?
When you say wrapped around the inside and outside wall...are you discussing a wrapped coil of tubes around all the walls of the enclosure or a back and forth "Z" type movement along one wall?
Anyway, there just seems to be many questions that would need to be answered before I could offer any type of legitmate help.
Mike
