Shear in Embeded Beams
Hi all
   what does ACI say about embeded beams ?
i have a beam with depth less than half its width (depth =30 cm, width =150 cm)
I use Egyptian code for design but it say i must check it for that all shearing stress must be resisted by concrete only and i must use stirupps of maximum distance between branches not more than 40 cm)
i see this very conservative!
RE: Shear in Embeded Beams
That sounds more like a narrow slab.  I would design it as a slab if the shear strength of the concrete is greater than the applied factored shear.
