Custom Number Format using "
Does anybody know how to define a custom number format to produce a double quote (" to represent an inch)?
RE: Custom Number Format using "
The Help file tells you to use a single backslash followed by the character you want.
TTFN
I'm not sure if this will help, but...
When used in formula's, four double quotes results in a single double quote
=+"Here Is a quote ->"&""""
returns
Here Is a quote ->"
Another example of the previous useage
displays
So a long way around would be to create a new sheet that refers to the corresponding cell in the first sheet.
All cells except the cell in question are A1 = +Sheet1!A1
The cell to be displayed in inches is A1 = +Sheet1!A1&""""
There may be easier ways but I'm not familiar with how the custom number formats work
Format | Cells | Custom and then use:
0/"
as your custom format
Good Luck
johnwm
________________________________________________________
To get the best from these forums read FAQ731-376 before posting
Thanks all - that does the trick!
On Johnwm's message I see three characters for the format string.
The 2nd and 3rd are / and " respectively
The first looks like a rectangle on my screen. What is it and how do I type it?
It's a zero (0).
Ken
