Molasses pumps
Molasses pumps
What type of pump shall I use to pump molasses with 120 tons per hour at 11.5 meters total head ( 2.5 suction lift plus 9 meters discharge head). Sp.gr is 1.4 and viscosity is 10000 cps.
RE: Molasses pumps
RE: Molasses pumps
you mentioned using screw feeder, i guess this is for horizontal suction line. Is it possible to install the pump above the liquid molasses level and be able to lift molasses at the suction ( suction lift)?
RE: Molasses pumps
I never heard very thick fluid at suction lift. Usually we use auger feeder to feed the pump.
Beside mono pumps, we can use piston pumps like Putzmeister or other concrete pump brands...
Remain with kindest regards,
Muwardi Santoso
RE: Molasses pumps
Can you suggest a website where I can learn more about molasses pumping systems.
olmedo
RE: Molasses pumps
Like stated above by mmmumuw I don't recall a material with high viscosity being pumped without a little suction head. On some highly viscous molten organic acids we used submerged pumps.
http://www.discflo.com/index.html
RE: Molasses pumps
I have some brochures of it. But when I see the manufacturer's homepages, I just find a showroom there. Perhaps I can scan the brochures. Reach me at santoso.muwardi@bumicahayaunggul.com.
