plasma cutting steel covered with lead paint
Is there a plasma cutting devise that will cut through steel covered with lead paint without causing vaporized lead emmissions?
RE: plasma cutting steel covered with lead paint
There are equipment that can remove the lead paint on the cut line and can be rented. It depends on your location whether you will be able to used the equipment or a licensed contractor will have to do the work.
If you can I would get a legitimate lead abatement contractor in for a consultation and see what they have to say. You may have to remove all the lead depending on the future exposure.
There is another possibility and that is to use a water jet cutter if the authorities will allow it.
If you can come back with your location that will help a lot.
Steve Braune
Tank Industry Consultants
www.tankindustry.com
