Leaking storm drain line
Very old 18" concrete storm drain line is leaking, we are considering rerouting or possibly lining approximately 200 ft of the line to prevent contaminated groundwater from entering it.  Does anybody know of an effective way to do this?  Cheaper is always better.  Any suggestions appreciated.
RE: Leaking storm drain line
You can consider chemically grouting the pipe or insituform if the pipe is structurally sound.
Good luck
Even if the pipe is ready to collapse, it can be lined with the CIPP method. Contact me at my mail address in profile. I may kknow contractors in your locale. If you are in the US
I would think the least expensive method is to punch through the old pipe with a new pipe.  the method is called pipe bursting. Less expensive than insitu form and potentially less expensive than retrenching and placing a new pipe.
Pipe Bursting-Trenchless Pipe Replacement
Pipe bursting is a trenchless method of construction used to rectify underground pipelines. A bursting tool replaces pipes by breaking them open from within by applying radial forces. A new pipe is simultaneously pulled in behind the bursting tool.
An expander device on the bursting tool pushes the fragments of pipe into the surrounding ground. A thin walled sleeve is generally pulled into the newly formed bore directly behind the 'expander'. This sleeve prevents the product pipe from being damaged by fragments of the old pipe in the surrounding ground.
Advantages
In comparison to conventional open trench method of pipe replacement, pipe bursting has several advantages that make it an economical option as costs is reduced by as much as 40 per cent.
1.  Upsizing
  One of the principal advantages of pipe bursting is its ability to increase pipe capacity by upsizing the original pipe diameter. This can be accomplished without excavation along the same alignment and grade of the original pipe.
2.  Structural replacement
  Pipe bursting provides total pipe replacement as a new pipe is structurally independent of the original pipe.
3.  Rehabilitation time significantly reduced
  Considerable time is saved compared to open trench methods with minimal excavation required to facilitate installation. As a result, the need for site reinstatement is reduced. The time to complete the entire installation decreases as much as 30 per cent.
4.  Reduced impact on traffic
  Pipe bursting reduces social costs associated with construction projects. Generally, when replacing pipes under a carriageway, only the localized area within a single lane is required to place the necessary equipment for the replacement job. Minimal traffic disruption will take place.
Do a web search for contractors near you.
