Portable Ultrasonic Flow Meter
Hello Everyone,
I'm looking for a portable ultrasonic flow meter to measure mine water (5-10% fine solids) in a 6" PVC pipe.  I've looked at Dynasonics and EESIFLO products. Does anyone have good/bad experience with them or other vendor suggestions?
Also, want should be the main features to look for in purchasing an portable ultrasonic flow meter?
Budro
RE: Portable Ultrasonic Flow Meter
Try Solartron Mobrey (www.solartron.com) and Katronics (www.Katronic.co.uk) for two.
Some day soon we may even have clamp on coriolis!
JMW
www.viscoanalyser.com
Eng-Tips: Pro bono publico, by engineers, for engineers.
Controlotron’s Clamp-On Transit-Time Ultrasonic Flowmeters have been field installed in critical applications globally since the early 1970’s. Experience, reliability, and innovative use of technology set our products apart. Patented Wide-Beam™ Transit-Time and Reflexor™ technologies assure accurate reading even in difficult applications. Being non-intrusive is the key to universal applicability to all industries.
http://www.controlotron.com/products.htm
Have good experience with this stuff.
Mount on vertical pipe with up-wards flow (like most flowmeters).
Good luck,
CARF
www.carf-engineering.com
