Selecting a CATPart or Sub-product to work in that document
I have a VBscript that works well in a catpart but it fails in a catproduct. I want to be able to select the catpart or a sub-product within the top-product to make it active and/or set the partdocument from the list of documents within the product. In the code below, assuming I don't know the name of document "PartName.CATPart", I need to have code to select the tree item and Set partDoc1 from that selection.
Sub CATMain()
Set doc1 = CATIA.Documents
Set partDoc1 = doc1.Item("PartName.CATPart")
>>> name not known, so I need to replace this line
>>> with selection process below
InputObjectType(0)= "AnyObject"
Set oSelA = doc1.Selection
oSelA.clear
Result = oSelA.SelectElement(InputObjectType, "Select Tree Item", False)
If Result = "Cancel" Then
MsgBox ("Command Canceled")
Exit Sub
End If
Set partDoc1 = oSelA.Item(1)
>>>> this is where I'm stuck. I can't get the document
>>>> out of the selection to set partDoc1
Set part1 = partDoc1.Part
Set hybridShapeFactory1 = part1.HybridShapeFactory
Sub CATMain()
oSelA.clear
Exit Sub
End If
RE: Selecting a CATPart or Sub-product to work in that document
You should also use .SelectElement2 rather than SelectElement if you want the code to run in R11 onwards.
to make active in whick to work. The 'Set partDoc1 = oSelA.item(1).Value.name' shows the name of the instance....'part1.1', its document would be 'part1.CATPart'.
Set doc1 = CATIA.ActiveDocument
InputObjectType = Array("Part", "Product")
Set osela = doc1.Selection
osela.Clear
Result = osela.SelectElement2(InputObjectType, "Select Part", False)
Exit Sub
End If
If osela.Item(1).Type = "Product" Then
' do some sub product code
Debug.Print "Selected Product"
ElseIf osela.Item(1).Type = "Part" Then
' do some part code
Debug.Print "Selected Part"
End If
If it is a product you need to use the PartNumber not the Name and you should be able to construct the appropriate document name from that, e.g.
set oDoc = CATIA.Documents.Item(selecteditem.PartNumber & ".CATProduct")
or something like that. However, you need to ensure that people don't select the 'Product node' for a part in the assembly tree (the node above the part in the tree). If they select the wrong node then the code assumes it is a product and not a part and you would get an error. You just need to put in some simple error trapping or limit them to just parts if this is possible.
Within a CATProduct, it works well up until the 'COPY' line. It errors with : Selected element not allowed for this operation!
It works all the way through within just a CATPart.
Sorry to pick your brain, but, got any ideas?
Code:
Language="VBSCRIPT"
Sub CATMain()
Dim InputObjectType(0)
Dim InputDocType(0)
InputDocType(0) = "Part"
Set ActiveDoc = CATIA.ActiveDocument
' Prompt to select destination part document if a Product is active
Set oActDocSel = ActiveDoc.Selection
Result = oActDocSel.SelectElement2(InputDocType, "Select CATPart", False)
msgbox result
Exit Sub
End If
Set DestinationDoc = CATIA.Documents.Item(oActDocSel.Item(1).value.name & ".CATPart")
oActDocSel.Clear
Set oSelB = DestinationDoc.Selection
InputObjectType(0)= "Face"
Result = oSelB.SelectElement2(InputObjectType, "Select a face", False)
Exit Sub
End If
oSelB.copy <---- Error:Selected element not allowed for this operation!
msgbox "copied"
End Sub
Try changing your script to:
Dim InputDocType(0)
MsgBox Result
Exit Sub
End If
Set DestinationDoc = CATIA.Documents.Item(oActDocSel.Item(1).Value.Name & ".CATPart")
oActDocSel.Clear
InputObjectType(0) = "Face"
Result = oActDocSel.SelectElement2(InputObjectType, "Select a face", True)
Exit Sub
End If
oActDocSel.Copy '<---- Error:Selected element not allowed for this operation!
MsgBox "copied"
You should perform the copying using the top level document selection object (in this case the active document).
I had to select the face first from a foreign CATPart within the Product, copy to clipboard , aquire the destination CATPart by selection, and Paste the Externally Linked Surface in the destination.
The only problem I have now is I want the program to check the selected Face properties to see if it is already in the selected destination CATPart and not foreign before I choose to copy/paste. In the full (larger) program, the face is used as a reference for creating normal lines through points.
Resulting Sample code that works:
Language="VBSCRIPT"
Sub CATMain()
Dim InputDocType(0)
Set ActDocSel = ActiveDoc.Selection
Result = ActDocSel.SelectElement2(InputObjectType, "Select a Face ", False)
Exit Sub
End If
ActDocSel.copy
ActDocSel.Clear
'Select Destination CATPart
Result = ActDocSel.SelectElement2(InputDocType, "Select CATPart", False)
Exit Sub
End If
Set WorkDoc = CATIA.Documents.Item(ActDocSel.Item(1).value.name & ".CATPart")
WorkDoc.part.InWorkObject = WorkDoc.part
ActDocSel.PasteSpecial "CATPrtResult"
WorkDoc.part.update
Set Ref1 = ActDocSel.item(1).value
End Sub
