Trying to locate textured b.c.c. sheet material
This question may be a little out of place in this format, but people have given me very good advice in the past in this forum.
 I am trying to locate some b.c.c. sheet material, preferably a b.c.c. Ti alloy, with <110> direction located in the plane of the sheet.  Thickness would be on the order of 0.030 - 0.060".  It is for a reseacrh project.
 If I can't locate a Ti alloy, I would settle for Fe or alternatively any b.c.c. alloy.
 Any suggestions?
RE: Trying to locate textured b.c.c. sheet material
CP Ti isn't bcc, and it textures like mad.  But I can't remember which direction is normal to the sheet.  They roll it from 20" thick to 0.020" with only stress relief and no recrystalization.  I don't know about some of the alloys.
Pure Fe doesn't texture much.  Alloys such as Si steels used for transformer laminations are processed to develop very specific directional textures.
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
