Reynolds Equation
Reynolds Equation
Hi everyone, I'm just drawing a blank here and can't remember the 1d reynolds equation..help?
RE: Reynolds Equation
There must be over 100,000 references to Reynolds' famous classical relationship on such search engines like Google. It would certainly behoove you to use that convenient and ample avenue for such basic information. But, since I already started this post:
Re = Dvd/mu
D = pipe inside diameter
v = fluid's average velocity
d = fluid's density
mu = fluid's absolute viscosity
The result, as you should know, is dimensionless; so make sure all your units cancel out.
Art Montemayor
Spring, TX
In the case of the Re, it is the ratio of inertia forces to viscous forces: ρL2V2/(μVL) = ρVL/μ as given by Montemayor. Where for pipe flow:
V=velocity
ρ=density
L=diameter
μ= viscosity
In consistent units.
http://www.carf-engineering.com/
Made by myself so it must be good ; )
CARF
hmmm
rmw
