sketch plane offset away from solid part
After I create a solid object, I go to Tool, Customize, Toolbars tab, Standard, New. In new Toolbar window select FreeStyle, WireFrame, Ok. Then I select Plan from the new wireframe toolbar with the Plane Definition window set to Offset from plane to create a plane 10" from XY Plane. After sketching on that plane, I could not extrude to the solid I create before. The Extrude Icon is disable. I follow the exercise from the Catia V5 Workbook release 5. Please help me if you know how to create offset plane or angle plane. Thanks
RE: sketch plane offset away from solid part
In order to have access to the Solid features, your solid need to be your working object. So select your (Part)Body, right clic / define in work object.
Eric N.
catiav5@softhome.net
There is an easier solution for planes.
Using PartDesign workbench select View - Toolbars. Check Reference Elements toolbar to be visible. Create planes (and points and lines) with these commands and your PartBody remains active all the time.
