Surface finishes
Surface finishes
Surface finishes
Where can I find information showing the equivalent SPI finish to a machined surface finish?  Example: 32 microinch is what in the SPI system.
RE: Surface finishes
Whiv,
I don't have access to a full list - but the most common ones I use are as below :-
SPI-C1: 600 grit stone, 10-12 Ra
SPI-B1: 600 grit paper, 2-3 Ra
SPI-A2: Grade #2 Diamond Buff, 1-2 Ra
I think in general the lettering follows the following convention
A   High polish   1 being the best finish grade
B   Paper finish
C   Stone finish
D   Dry blasting
You can find out more information on SPI finishes on their homepage at http://www.plasticsindustry.org/
Hope this helps
Sean
Sean:
    Thank you for your reply.
Hector
