Save to PDF Add-in not found
Working with SWX 2004 SP03 & SWX 2003 SP05.
I recently received a new computer at work and both 2003 and 2004 were loaded. On my old computer, I had the 'Save as PDF' option available in both versions. Now I do not have it in either and it isn't even one of the options in the Add-in dialog box.
Is it possible that the systems guy didn't load the 2004 properly?
Was there an option that should have been checked in the loading process?
I'd appreciate any insight I can get,
Lori
Lori
RE: Save to PDF Add-in not found
Heckler,
You don't need Acrobat to save out PDF from SW. It was included in SW04 version of SW.
Scott Baugh, CSWP
to me
http://www.3dvisiontech.com
http://www.scottjbaugh.com
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
I looked in my Windows printer dialog box and I do see 'Auto Bluebeam PDF Printer on PROD100'.
My new computer has Windows XP Pro, do you think maybe that has something to do with it? My last computer was Windows 2000 and I was able to use the PDF fine.
It's just weird that the 'Saveas PDF' isn't even listed in the Tools/Add-ins box.
Lori
Uninstall and clean the registry out - clean not only SW but also Bluebeam from the registry. Remove the printer if it doesn't remove itself automatically when uninstalled.
Scott Baugh, CSWP
to me
If your in the SW Forum Check out the FAQs Forum559
To make the Best of Eng-Tips Forums FAQ731-376
