Create a Lisp help for Grading site plans
I need to know how hard it is to create a lisp which will do the following:
1 - Pick a place on the drawing which places a leader or spot X.
2 - Then Prompts for an Elevation XXX.XX with a rectangle around it.
3 - Then takes the XXX.XX value and adds .50 to it and places it above the value which was entered in a block
4 - finally, user pics a place for the block to be placed with the leader or line which connects the block to the spot X.
hope that s not confusing! thanks!
RE: Create a Lisp help for Grading site plans
Form Step 3 to Step 4, I am not clear.
And it use for survey ?
_______
| XXX.50 |
| XXX.XX |
If you can do some part funtion like make a rectange, leader send me the child funtion , I will combine for you
kientruc75@yahoo.com
-Click on ACAD point
-Program prompts for elevation
-Program draws label and leader
-Repeat from top
