Numbers for 5/8" weld
The company I work for has had an ABB robot for 2 years and is just now setting it up for production. My job is to make the robot do what our welders are currently doing. The only problem is that I can't get a 5/8" weld to work out. I was wondering if anyone has suggestions on gas, voltage, weave size and type, wire feed, travel speed, dwell, or any other data that would come in handy.
RE: Numbers for 5/8" weld
http://www.weldreality.com/default2.htm
1)what are you fabricating,
2)what position are you trying to weld, downhand, horizontal etc
3)what do you mean by " can't get the 5/8 welds to work out"? are they cracking, are they the wrong shape, are they the wrong size?
